![]() | Home > General > Buying a 2008 TDV8 - what should I look for? |
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533
If it's been sat around then the Electric Park Brake could become an issue. Others on here have found this, and mine failed within weeks of buying it having sat on the forecourt for a few months and only covering 500 miles the previous year. 13MY Range Rover Sport Autobiography SDV6 - mine
| pablo Member Since: 21 Sep 2017 Location: Watford Posts: 4
Good to know, I heard the electronic parking break is about a 2K repair, is that even remotely accurate? Sounds extortionate! |
£2k is rather exaggerated. even at main dealer rates...
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9155
The EPB issues are usually at the wheel hub end, not the module itself. The brake shoes do need to be maintained and adjusted. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Turbo's can be a problem too |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
So can fuel consumption. |
Thanks for the tips guys. I'll be extra vigilant tomorrow, thankfully the owner is going to get it MOtd too so i shouldn't have anything to worry about! |
Not to sure about that one theirs loads of other parts to worry about that are not under the mot like air-con,electrics etc |
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322
There is a buyers guide around somewhere. Worth a read.
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1562
I bought a 2008 TDV8 20 months ago. Without a reasonable warranty I would be seriously out of pocket. You would not expect the items I've had repaired to go at just 60 thousand miles but, from memory, (as I'm on hols at the moment) front diff, 2 wheel bearings, both front lower wishbones, EPB seized. So far I've had some £1600 paid for by my warranty company at a cost of £925 and I still have 20 months of warranty to run.
Who did you opt for with the warranty, Eaters? |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
You wouldn`t like mine then |
When I bought the car I was given the "Ultimate" option from The Autogroup (www.theautogroup.co.uk). I'd never heard of them before but they seem to have looked me quite well. One thing they don't cover, and you may not even think to check it on when you buy, is the headlamps. If its fitted with the AFS (all singing all dancing) headlights, and they are not working properly, then a brand new replacement headlight is just short of £1000 (second hand about a third of that). Yes, that's EACH! There are plenty of threads on here (including mine) about the issues with them. Seems its an intermittent fault, so be careful to check as much as possible. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
Why don't they cover AFS lights ? cus its an option ? |
| All times are GMT |
