Home > Technical > Help rrs just cut out and won't start.
Ste815l
Car just cut out and will not start. Engine cranks fine but nothing doesn't even try to start. I sprayed bit if engine start and it did fire up till I stopped spraying. Phoned breakdown cover he tried to scan fault codes found modules but wouldn't scan them was saying error connecting. He says canbus has shut down any ideas ppl. It's a 2006 2.7 thanks
Post #536174 Fri Sep 22 2017 2:39pm
Remove engine cover and see if fuel present at the tyre valve at the rear of engine
Post #536188 Fri Sep 22 2017 7:12pm
Ste815l
Did that no fuel or pressure. It's either fuel filter blockage lift pump has failed or canbus has gone down shutting all modules.
Quick question can only diagnostic readers with land rover software connect to modules. Just that breakdown recovery fault code reader would not connect canbus making me think it's shut down.
Post #536190 Fri Sep 22 2017 7:21pm
