Home > General > Special program not available
Bulletsaints
England 2005 Range Rover Sport TDV6 SE Java Black
Little update on this, ok so just fitted a new brake light switch as people have mentioned and thought it done the trick !! So now when I first start engine I can now flick through the terrain settings, I couldn't do this before !! But, after around 20 seconds I get the bong sound and system fault special program not available pop up, then terrain settings don't do anything and no lights on the knob etc. Any ideas ?? I am planning to have it plugged in its just getting time
Post #535898 Tue Sep 19 2017 5:44pm
Brake light bulbs will cause this
HDC relay fault would also do this as would an ABS issue (although that should throw a light on the dash).
Terrain Response responds to faults in other systems. Other than a faulty TR module, which is unlikely, the issue will be elsewhere.
Fault codes will help. 2012 SDV6 - it's missing a couple of cylinders
Post #535974 Wed Sep 20 2017 10:51am
Bulletsaints
Thank you !! So is it dealer only for the brake bulbs or is there a particular brand to buy as I no not all dealers use or stuff as I used to supply main agents with aftermarket parts. Also is there just 1 hdc relay if i was to ask for one and where would i find this ? Thanks again
Post #535976 Wed Sep 20 2017 11:49am
quality bulbs like osram, ring should be fine
Post #535978 Wed Sep 20 2017 12:21pm
GodivaNige
I had similiar issues when I first owned the car, a new brake light switch and Osram tail/brake bulbs cured the problem until the alternator failed, then the same alarms were occasionally appearing.
Just last month started getting special program faults again and read a fault code along the lines of transfer box clutch at limit. This was down to a poor electrical connection at the transfer box, separated the plug, squirt of contact cleaner and no further fault codes.
Special program faults, HDC faults and high/low range faults appear for all manner of reasons which call for a little detective work to find the culprit, usually electrical. All part of the fun Thumbs Up
Post #535981 Wed Sep 20 2017 12:28pm
Bulletsaints
Thanks all..... does it matter what make the brake switch is ? Mine was only £1e from mpd
Post #535984 Wed Sep 20 2017 12:35pm
HDC relay is hardwired in to the engine bay fuse box. I guess that means a new box. That's going to be a non-trivial cost. 2012 SDV6 - it's missing a couple of cylinders
Post #535986 Wed Sep 20 2017 12:42pm
Bulletsaints
Ok so done brake switch yesterday, just done brake bulbs and both was a little black so replaced with osram bulbs, still getting specai program not available ? One thought tho is I have no high level brake light because I have a none standard tailgate top spoiler !! Should there be a top brake light ? Could this be an issue ??
Post #536003 Wed Sep 20 2017 5:20pm
geoffsnook
I take it this problem has only just occurred on the disco and the spoiler has been on for a while so that should not cause the issue Thumbs Up
Post #536005 Wed Sep 20 2017 5:41pm
Bulletsaints
This issue was on the car when I brought it and sò was the spoiler ?
Post #536006 Wed Sep 20 2017 5:46pm
geoffsnook
Next step is to get the faults read then as i assume there are no warning lights on the dash to give you a clue as where to start and no battery issues that your aware off or any spill/fluid marks around the area Thumbs Up
Post #536007 Wed Sep 20 2017 5:56pm
Bulletsaints
Charged battery over night while still on the car, had a friend use a hand held ßcanner and came up u0100 but trying to sort out getting it on a proper machine Thumbs Up
Post #536008 Wed Sep 20 2017 5:59pm
A missing spoiler brake light won't cause it
Post #536011 Wed Sep 20 2017 6:18pm
geoffsnook
yeah it does need to be read with a proper land rover tool anyone near you got an IID or nanocom you can ask them to read the codes for you i had similar to you except the button's did stuff but used to come up with hdc fault and special programs not available and that was the battery but yours seems a bit more than that do the high range switches and suspension switches work Thumbs Up
Post #536012 Wed Sep 20 2017 6:20pm
Bulletsaints
Yes high low works fine and so does air suspension, everything works untill the message comes up the terrain light on knob goes out
Post #536015 Wed Sep 20 2017 6:31pm
