Home > Faults & Fixes > Issues
rangeroverloon
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Issues
Hi guys
My 2010 Range Rover sport won't go into access mode. I have changed all the shocks and also changed all of the valves. I have gone through every single sinario and just won't go into access mode and just says going into extended mode. I have changed everything compressor valves , height sensors checked all pipes and wiring and still having issue.
Can anyone shed any light have I missed something all help would be appreciated before I burn it.
Many thanks
Post #535595 Sat Sep 16 2017 2:29pm
Tyrefitter
I would message Bodsy,,or one of the tech guys on here they will probably be able to help Thumbs Up
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #535597 Sat Sep 16 2017 2:50pm
rangeroverloon
Hi thanks for that I new to this site don't really know anyone but I'm from Surrey so if anyone could help that would be great and much appreciated.
Thanks
Post #535598 Sat Sep 16 2017 3:02pm
DrRob
Here you go:
http://www.rovertune.co.uk
http://mooreautomotive.co.uk
https://www.hunterslandrover.co.uk/retail-...ce-centre/
http://conricoservicecentre.com
http://www.rrlondon.co.uk * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #535599 Sat Sep 16 2017 3:36pm
Paddi
The usual reason for that behaviour is that someone has changed the ride height to be lower. If the ride height is changed by say 10 mm then all ride heights (access, standard and offroad) are reduced by the same amount. If ride height reduced by more than 15mm then it is possible for the access height to be so low it hits the bump stops and the car thinks it is grounded and goes into extended mode to clear the obstacle it thinks is there.
If this is your problem then all you need to do is reset the ride height to standard measurements and calibrate the height sensors and all will be well. You need a diagnostic tool to do that so buy one or go to a local specialist. 2008 MY Java Black TDV8 HSE
Post #535605 Sat Sep 16 2017 5:05pm
Aussie2012rrs
Australia
Have you replaced the pump?
I had same issues and tried everything you did doing my best to avoid replacing the pump. My logic was that because it is able to go to extended mode then the pump should be find. Must be valves etc. Well at the end I just went ahead and replaced the pump since I hunted around and found a oem replacement one pretty reasonable ($750aus), under 300£ in online, and solved my problems. If I went straight for pump would of saved me hassles and hours reading forums and trying all the easy fixes.
Good luck.
Post #537936 Tue Oct 10 2017 7:26am
