![]() | Home > Technical > Rear Suspension Settling |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
There are lots of threads on settling suspension - mine is settling at the rear - equally on both sides - air leak or valve block.
Thanks - nothing on the suspension system has been touched or serviced in its life so I may have to have a look at that.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
I would pull the EAS fuse and see whether it still drops. For not, it's something electronic. If it does still drop them it's a leak. 2012 SDV6 - it's missing a couple of cylinders
Thanks for the information - is that fuse an engine bay or cabin fuse?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
Engine bay.
Thanks I will find it.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
garrycol - Out of interest, when you park up overnight are you on flat ground or on a gradient? Barrie.
Is normally parked in my garage so on flat ground. 07MY RRS TDV6
