![]() | Home > Faults & Fixes > Strange noise... |
R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32 ![]() ![]() ![]() |
Ok so I've been under the car today and found that the heat shield fitted in the middle of the car between the exhaust silencer and propshaft was loose due to the washers pulling through the Tin plate I've removed the plate and found the propshaft center bearing worn/ rubber split, I'll replace both and see if this solves the noise |
Right I've replaced the center bearing and the noise is still there. Anyone one got any suggestions?? Catalytic converter maybe?? |
Corroded brake backplates flapping about? Easy enough to check if you can get it up on a lift. 2008 MY Java Black TDV8 HSE
Yeah Thays worth a look I'll have to get it on a ramp and see what's going on |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
One that happened to me was the EPB cable had come out of the hook that keeps it against the suspension arm. It's in the rear wheel well on both sides. It was rubbing on the wheel and made a similar noise to the one you describe. Easy to push it back in to the hook. 2012 SDV6 - it's missing a couple of cylinders
Ah ok thanks I'll check that, I'm hoping it's something simple and not some kind of horror story like a noisy camshaft chain or something |
Thanks for the suggestions I've checked to find all ok, I am now thinking maybe its a pulley or belt tensioner has any one has issues with pulleys or a belt tensioner? |
Citizen55 Member Since: 14 Dec 2015 Location: Rollin' in my Five point O (well, 4.2) Posts: 55 ![]() ![]() ![]() |
I have the same issue, it's subtle as hell, my my OCD knows the noise is there. I thought it was torque converter although I haven't had it checked out. Any luck solving yours? 2006 Range Rover Sport 4.2 s/c with Arden bodykit |
Hi Citizen55
mikeyjones70 Member Since: 03 Jan 2018 Location: west bretton Posts: 3 ![]() ![]() ![]() |
Morning
