Home > Technical > iid tool
Beeawreet
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
iid tool
hello to all the forum from a newbie member..wondering if anyone knows if I buy the iid tool I would be able to switch on park heating on my 2008 sport hst 3.6 v8.?..cant work out from research if it is hidden in the ecu or landrover never put it there in the first place..it has the webasto thermo top v fitted under the lid..many thanks and sorry if this subject has been talked about in previous threads but I had a quick look and didn't spot it. Embarassed
Post #534931 Sun Sep 10 2017 5:40pm
geoffsnook
It should come on when the temp drops below 5-6 degrees or if you read the manuel on the IID tool website it tells you how to test fire it Thumbs Up
Post #534935 Sun Sep 10 2017 6:33pm
I think u need to buy a £250 part to be able to turn it on from your remote key
Post #534936 Sun Sep 10 2017 6:40pm
geoffsnook
Have a look here Thumbs Up
https://www.disco3.co.uk/forum/topic153175...ark+heater
Post #534938 Sun Sep 10 2017 6:49pm
Beeawreet
hi thanks for the info/suggestions..the altox thread is for a disco.?.does this apply to me.?...although the iid tool would be useful for so many more things I need to know if a range rover sport 2008 has the option for timed park heating.(therefore able to blow warm air into the cabin) hidden in the ecu files and able to be enabled)..as buying the diagnostic tool would be an expensive experiment if its an impossibility..thanks.
Post #534945 Sun Sep 10 2017 7:49pm
geoffsnook
They are very similar cars and you would need a kit to turn on the fbh as that software was removed on earlier cars including yours i would suspect with a software update from land rover why do you ask if you can turn it on and by the way having access to IID tool or similar is almost a must with these cars or knowing a friendly indi who can help Thumbs Up
Post #534947 Sun Sep 10 2017 8:05pm
Bodsy
Site Sponsor
You don't need to enable anything on your year car, you just need to fit the Altox kit that I sell (just taken another delivery in prep for winter!)
Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #534950 Sun Sep 10 2017 8:16pm
Beeawreet
Ok I think I will go with the altox suggestion and also invest in the iid tool..thanks for the forums help. Bow down
Post #534969 Mon Sep 11 2017 8:46am
donny dog
Any dates yet on when the tool might be updated to enable MY17 cars with FBHs?
Post #534980 Mon Sep 11 2017 10:07am
DrRob
Bodsy can supply and fit it for you and you won't need to buy an iiid too saving you dosh...and he's mobile Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #534986 Mon Sep 11 2017 11:52am
Beeawreet
Ok thanks for that Donny dog.
Post #535023 Mon Sep 11 2017 3:22pm
