Home > Maintenance & Modifications > Parking brake came on when fitting new shoes.
Joe Hankey
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Can anyone please help me the parking brake has come on while i was fitthing new shoes can anyone tell me how to get it off so i can fit the newones the disc is off and i only have the new one on the brake. Big Cry if you live near warrington that would help me thankyou.
Post #534257 Fri Sep 01 2017 12:21pm
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Did you follows Bodsy's brake bible?
https://disco3.co.uk/gallery/albums/userpi...1.4sml.pdf
Hopefully something in here will help you.
Post #534258 Fri Sep 01 2017 12:27pm
Joe Hankey
Yes but the litte one put the hand brake on when i had it striped down any help would be appreciated thankyou i had done one side then thhis has happend.
Post #534259 Fri Sep 01 2017 12:41pm
Joe Hankey
I cant get that up
Post #534260 Fri Sep 01 2017 12:45pm
Scrumpy
Don't know if it helps or not, but you can manually release the parking brake by pulling on a cable underneath the centre console behind the gear stick. here's a link on YouTube showing how easy it is;
If that doesn't work, you may need to manually adjust the shoes by turning the little knurled wheel to release the shoes. Once done you might be able to reset the whole thing by following the set up procedure.
Good luck and let us know how it goes. 2016 RRS SVR Estoril Blue
Post #534263 Fri Sep 01 2017 1:16pm
Bodsy
Site Sponsor
That's a real pain. It's why I tell people to remove fuse 8 as it would have prevented this issue Sad
You may have to manually wind the EPb module back out.
I'm guessing that it had a real screech when it was applied? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #534268 Fri Sep 01 2017 1:51pm
Joe Hankey
Rangeroversport 2.7 2006 brake shoes locked on
I had to go into the computer programs and reset the brakes. It took 10 minutes all finished now thankyou all for your help. Thumbs Up
Post #534499 Mon Sep 04 2017 10:49am
Paddi
Good result.
Think you were lucky at two levels there. Could have lost a finger or two when the brake was activated and didn't need to dismantle the EPB module.
Always always put the EPB into service mode and remove the fuse when working on the rear shoes folks. 2008 MY Java Black TDV8 HSE
Post #534503 Mon Sep 04 2017 11:58am
