![]() | Home > General > U0434 code |
typhoo12 Member Since: 10 Nov 2016 Location: United Kingdom Posts: 40 ![]() ![]() ![]() |
Updated
Most critical safety warning lights/messages fail the MOT I'm afraid. Does it come on from start and when stationary? John
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
Might be worth getting the steering angle sensor checked / calibrated. 2012 SDV6 - it's missing a couple of cylinders
Another really silly thing that causes all sorts of fault errors, have you changed your brake light bulbs, or have one out/faulty?
The reason brake bulbs can play havoc is because they are activated by HDC which is hard wired in to the ABS system and Terrain Response etc. So a blown bulb causes a fault in HDC which means TR doesn't work ("Special Programmes Unavailable") and can lead to other systems getting arsy too. Also, because of the CANBUS, strange voltages can cause strange errors and bad bulbs can cause strange voltages. 2012 SDV6 - it's missing a couple of cylinders
