![]() | Home > Maintenance & Modifications > Rear parking sensors |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5136 ![]() ![]() ![]() |
They won't click with the park brake on
you didn't disconnect the parking speaker when it was annoying you? |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
If the speaker is faulty you should recieve an error message on the dash stating that the sensors aren't working (not sure if it's a default message, but for mine when the speaker died it said the front sensors weren't working) |
He may not have front sensors.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
This may help as I've just had a go at mine. It's possibly a common fault with the routing of the wiring loom as when I took my bumper off and had a look someone had done a botched repair before me. However one wire had (once again?) parted company and once replaced my sensors are working fine.
Thanks for the responses.
