Home > Technical > Help with error codes
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Getting some error codes on a regular basis now, when this happens the suspension seems to be non existent, the cruise control, Acc and forward alert doesn't work.
Clearing it with the gap tool puts the car back to normal then pops up again shortly after. I do have a LR Warranty but would like to try and find out what it is before it goes into the garage. Any help would be appreciated.
2012 autobiography.
First time:
ADCM-Active Damping
• U3000-47 (AF) Control module - System internal failure - watchdog/safety failure
CCM-Cruise Control
• U0401-81 (AF) Invalid data received from engine control module/powertrain control module - Bus signal/message failure - invalid serial data received
( on 11-12-2012 14:01:16 at 0 km )
PCM-Engine SDV6
• P0700-00 (2F) Transmission control system (malfunction indicator lamp request)
( on 26-08-2017 10:23:52 at 44629 km )
TCM-Transmission 8spd
• U0100-63 (AC) Lost communication with engine control module/powertrain control module 'A' - Algorithm based failure - circuit/component protection time out
( on 25-08-2017 14:37:58 at 44629 km )
Second time:
ADCM-Active Damping
• U3000-47 (2Cool Control module - System internal failure - watchdog/safety failure
ARCM-Active Roll
CCM-Cruise Control
• U0401-81 (2Cool Invalid data received from engine control module/powertrain control module - Bus signal/message failure - invalid serial data received
( on 26-08-2017 14:50:55 at 44655 km )
PCM-Engine SDV6
( on 26-08-2017 16:17:10 at 44660 km )
• U0100-63 (ACool Lost communication with engine control module/powertrain control module 'A' - Algorithm based failure - circuit/component protection time out
( on 26-08-2017 12:04:14 at 44655 km )
Any help greatly appreciated.
Post #533891 Sun Aug 27 2017 8:44am
Gerd1986
Bump
Post #534004 Tue Aug 29 2017 8:41am
looks gearbox related. But who knows
Post #534011 Tue Aug 29 2017 11:39am
Gerd1986
Thanks Andy, trying to get it booked in which is a nightmare in itself!
Post #534020 Tue Aug 29 2017 12:46pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
I would say that there is something interrupting the comm's on the bus, as the errors look a bit like major communication failure. Try looking at the underbody connectors and check that none have been damaged.
Post #534295 Fri Sep 01 2017 5:46pm
