Home > Maintenance & Modifications > Suspension compressor
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Recently had the 160 000km service and one of the comments was that there was a leak in the system they didn't know where from but could have a look for a couple of hours @ 100€ / hour. But he reckons to change the whole compressor @ 1500€ plus work.
Given he didn't know where the leak was coming it sounds odd to change the compressor.
I figured i would check myself the air dryer cap, which is a common fault.
Finally was able to get under the car but what i've seen isn't what i wasn't expecting.
The compressor unit looks different than those i've seen on youtube videos or pictures
I was expecting to see something like this:
What i can also see on the compressor are some dates from February 2015. This makes me believe the whole unit was changed 2 years ago??
Based on the compressor unit i have, would i still get the cracked cap as per all the other posts i've read?
I haven't had any warning lights come on regarding suspension since the service.
cheers 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #533967 Mon Aug 28 2017 5:45pm
no point changing a 2 year old compressor.
Is the car low down on the ground when left overnight? If not, don't worry
Post #533968 Mon Aug 28 2017 5:53pm
Pakolainen
It's parked on gravel that moves a lot, sometimes it looks like the rear left is lower but then - uneven ground.
It raises fine and lowers fine.
Reckon i might put the fault codes down to being old also, especially as i've had no errors since the service. and the 'change the compressor' to grease monkey trying it on.
cheers
Steve 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #533969 Mon Aug 28 2017 6:00pm
DrRob
I have a slight slope to my drive. Car self levels on there. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #533983 Mon Aug 28 2017 8:18pm
If there is a leak the whole car drops overnight
Post #533987 Mon Aug 28 2017 8:44pm
