![]() | Home > General > Jacking Adapter |
| TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96
I need one too |
| myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433
I'm interested also. |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
The real problem with the provided jack is not so much getting it up in the air, but when it gives way. Note to all: Do not trust the provided jack. I have the Clarke jack you mention and have been meaning to get hold of an adapter for it. It works fine without one though so don't wait to get one for that though. Since I rarely use the actual jacking points, I suppose it would not be of much use to me anyway. Would be a good idea to get a bottle jack to keep in the car too. 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver
| bonzer Member Since: 16 Mar 2016 Location: Staines Posts: 35
Hi All,
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
ive got a proper lift or 3 |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Jack it up under a wishbone front or rear using a trolley jack or a decent bottle jack.
As DrRob says |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
The OP could take a copy of this drawing to a local engineering shop and request they make him one up in stainless, aircraft grade aluminium or boring old steel. If he was to have several made there is a healthy demand on this forum.
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Now that is one clean Jack Paddi, not seen much use. Have you had it detailed |
Sadly those pictures were plagiarised from an old Disco 3 thread. Be assured my own 3 ton SGS trolley jack is covered in dust dirt and grease just as it should be. 2008 MY Java Black TDV8 HSE
| W55*** Member Since: 01 May 2015 Location: Derby Posts: 7
Beware of cheap alloy ones that are prone to snap apparently. |
| All times are GMT |
