![]() | Home > General > Main dealer or independent? |
| ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331
I now use an specialist independent, better value and I have more confidence in the work undertaken.
| donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772
Do independents get access to the electronic system that records services? If they do, I can't personally see a problem assuming they use original LR parts. If I were buying second hand, that's all I'd want to see. (Having said that, some sellers make a big play on 'Full Dealer Service History', but you'd probably save a lot lore than you'd lose on any sale). |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
If it's under warranty then I would still use a main dealer.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
A decent indie every time. The warranty is still ok so long as the correct schedules and parts are used. The big difference is that you'll get a better job done for your money and it will be cheaper too. Double win. |
I'll 2nd that |
I'll probably use West 4x4 as my motor gets a bit older |
| Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 426
Spoke to a independent yesterday about having the 5 year service and they said £349 with patten parts or whatever the extra cost is of genuine parts plus this included the change of the transfer box oil which the main dealer said was extra but recommended.
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
My Sport is now 6 years old, had a Main Stealer service, plus had the belts done (I know 12 months early) Just a Tad under €2k |
Might have been cheaper to bring it to Blighty for the day... |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
I have only ever used main dealers, as haven't found a decent LR independent, unless anyone knows of one, or can recommend one that's either near to North Wales (Llandudno area + up to 50 miles), or North Yorkshire (Scarborough). Many thanks for any advice.
I thought the cost was not too bad for a main Stealer, it was a 6 year service, brake pipes etc as recommended by Land Rover plus I had the timing belts done. Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
| All times are GMT |
