![]() | Home > General > Engine top end strip down |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
I'm now at the rear cam pulley. Thought I read somewhere that the casing had to be cut/destroyed to gain access to the cam pulley bolt. How do I at least attempt this one? ![]() P38 4.6 HSE V8 |
Got the rocker cover off and removed cam shafts to gain access to the 8 head bolts. Next job to tackle will be fuel pump side. What's to be done at this stage? ![]() P38 4.6 HSE V8 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
good work.
Cheers... I think the chain tensioner is OK, I lifted it out along with the small spring.
That's correct. |
would recommend you get this on order from china.
if/when it comes to needing heads, I would recommend these guys.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Curious Andy, how did you torque up the rear cam pulley bolt? |
I removed the cam with the wheels still on, with the belt cover hanging around it |
I'm starting to undo the high pressure fuel pump tensioner bolt, total pig to get to. What's the score with taking the belt off at this stage, do i just continue to take the tensioner bolt fully out. How does the belt slacken.
2.7 belt isn't timed, so take it right off
80Nm then 90 degrees ![]() Cam seals need fitted in place once the cam caps have been torqued Then the cam pulleys need fitted and tightened... |
Good stuff thanks DM. |
