Home > General > Top Turbo Hose???? Black smoke
Ferret15
United Kingdom 2008 Range Rover Sport TDV8 HSE Sumatra Black
Me again. Not a great couple of weeks, first a major milk spillage. Thank you all for the ways to get rid of that smell and how to give if a proper clean.
However when my wife was driving back from London on the weekend. She had a loss of power and a message pop up "system engine failure" she thinks it said. Now she says that she was going a little north of 70mph when it happened. Pulled over restarted the car and all back to normal. The car felt like it was struggling for a while but then fine. It also did it on a hill near home.
As soon as she was back I check to see if there was any smoke coming out the back. Not a lot but a little black smoke when you really rev. After a quick look through this forum I narrowed it down to be the top turbo hose (I hope).
Took it down my local and told them what I thought. They couldn’t find a split but said one of the sensor was extremely dirty so gave it a clean. All work fine for a day (still black smoke tho) and then same thing happened again but only on a steep hill. The local said they will order a new sensor. I also just got to work after driving it in and it drove lovely. I even gave it some heavy footing.
But I have a question about the hoses. One of the hoses is considerably softer than the other. Is this how it should be? Should I just replace the top hoses to rule of that possible being the problem?
Sorry to rant on. Thanks again
RRS 08 TDV8 3.6
Post #532471 Thu Aug 10 2017 6:50am
Ferret15
Should have added no warning lights
Post #532474 Thu Aug 10 2017 7:52am
Stevepd
It could be that the material is simply old. I've had it on other turbo cars with a few years on them and its simply degradation. Back in the day of Cossie ownership some of the BIG boost cars could suck close the standard hoses, then the metal versions started to come out.
Steve.
Post #532485 Thu Aug 10 2017 10:28am
Ferret15
Thanks for the reply stevepd
So after having a good look over the hoses. I have found the split and not a little split. Not really sure how the missed it. Unless it got bigger over the last couple of days.
Has anyone used silicon hose instead of the LR hoses? I’ve been told they are much more reliable. Any thoughts?
Post #532547 Fri Aug 11 2017 8:18am
The top hoses don't split that often - they seem to last several years at least - so a "more reliable" hose is an odd idea. Silicone hoses are 2 or 3 times the price of the LR version so probably a false economy. They are cool though. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #532550 Fri Aug 11 2017 9:39am
Ferret15
RRSTDV8 i went with the LR part. Its already an old rig so im sure the rubber hose will out live the rest of the car. I hadnt looked at the prices of the silicone either.
Post #532555 Fri Aug 11 2017 10:03am
Ferret15
Fitted the part last night. Such a big difference. Seemed to sound better, gear change better and felt like it had so much power. I'm now wondering if there has been a small split in it since my ownership (4month) because its never felt so nice to drive. Thumbs Up
Post #532625 Sat Aug 12 2017 5:57am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi Ferret15. Pleased to read you got it sorted. Out of interest, how much did you pay for the hose and was it fairly easy to do? Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #532627 Sat Aug 12 2017 7:09am
Ferret15
BJH1959 they are nice and cheap eBay £25.00 here is a link
http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...Swr~lYsCi4
And it’s probably the easiest job you will ever do on a RRS. You basically lift up the engine cover for easy access. Undo the screw, bolt what every you want to call it. Take the split hose out and replace.
The instant difference is unbelievable. Still has a bit of black smoke but I guess it will take some time for the system to clean out.
Post #532634 Sat Aug 12 2017 8:28am
Ferret15
The link is for the LH Turbo hose. I think the RH is maybe even a little cheaper.
Post #532635 Sat Aug 12 2017 8:29am
BJH1959
Thumbs Up Barrie.
Post #532659 Sat Aug 12 2017 3:51pm
