![]() | Home > Technical > 4.4 petrol sport, fan seems to be running all the time |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5060 ![]() ![]() ![]() |
I thought they had a vicious fan, which is driven by the engine, and would be moving all the time. |
Your viscous van may be knackered there is a bi-metallic strip that when it heats up it looks the fan on and when its cooler it stops the fan spinning all the time so yes when its at normal operating temp it should not be spinning apparently you can actually hold it but would never recommend trying it |
Tom55 Member Since: 24 Mar 2017 Location: Wolverhampton Posts: 27 ![]() ![]() |
Thanks for the help, is it at all related to the air con? I only ask as i noticed it was on all the time but after i had turned off the engine etc and on the way home it was normal, no noise etc, the difference was i had the a/c on but didnt on the way back when it was fine |
The van will run more when air-con is on but get it checked if you can |
yes it will run faster with the air con on.
