![]() | Home > General > Steering wheel wobble |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Shouldn't need an alignement after changing the bearing, Have you knocked a wheel weight off by accident whe removing/replacing the wheel ?
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Hi Socast
RRSRobC Member Since: 31 May 2017 Location: Laleham, Surrey Posts: 23 ![]() ![]() ![]() |
I had steering wheel wobble when breaking from higher speeds. Quite embarrassing when you have passengers wondering why your jiggling up and down in the driver's seat.
I feel your pain RRSRobC |
I forgot to mention, it could also be that your wheel is buckled.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
1. did you check that the mounting surfaces of the disc and the bearing were completely clean and smooth?
Hi Socast
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Its not a Range Rover sequence its just basically tighten each nut in turn diagonally across from each other, plus I would question the 140nm, I thought it was 96 |
Install the wheel and tire.
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
I have had the same in the past with a different car. Turned out on that occasion the new hub itself was buckled causing the wobble. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
IAWA 4x4 in Wellingborough. A little journey, perhaps, but worth it if it saves you a decent amount. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
140Nm / 103 ft-lb 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
UPDATE ....
Noted! Thank you 2007 L320 3.6 TDV8 HSE Java Black 2010 W204 C350 AMG Black 2007 E93 325i M Sport Black II 2004 E46 330ci M Sport Black II |
