Home > Maintenance & Modifications > Service done, host of fault codes cleared |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
Blank the EGR's. Very simple on yours. Shouldn't need any software updates. |
Sun Jul 30 2017 12:47am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Changing the compressor is not going to fix a leak in the system - if the leak is not fixed (not hard to find) the old or new compressor will run more than it should and wear out. 07MY RRS TDV6
Sun Jul 30 2017 2:17am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
Disco 3 sister site has a number of threads on how to find leaks. Grab a coffee and do a search Visitor from fullfatrr.com
Sun Jul 30 2017 5:30am |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Thats pretty much what i told the mechanic. You couldn't find the leak but a new compressor is the way to go???
Sun Jul 30 2017 2:17pm |
Sounds like you need to find a different mechanic too. Find a LR specialist 👍 Visitor from fullfatrr.com
Sun Jul 30 2017 2:29pm |
The garage is a Jaguar / Land Rover specialist.
Mon Jul 31 2017 9:22am |
The fact it's not building pressure and can't vent properly says to me that the issue is probably one of the valve block, do you come out to the car and find it's leaning or sat at a funny angle ?
Mon Jul 31 2017 10:44am |
It may be slightly leaning lower on the rear left hand side, but ever so slightly. No red marks on the 4x4 info screen tho.
Mon Jul 31 2017 12:34pm |
Might be worth disconnecting the battery overnight, that will stop the system trying to self level and point you at the corner that is leaking (if it is a corner)
Mon Jul 31 2017 1:54pm |
Just measured centre hub cap to wheel arch. Car has been stood still in access mode for 22 hours.
Mon Jul 31 2017 3:39pm |
You'll want to leave it at normal height as the car can't drop much more when it's in access height. |
Mon Jul 31 2017 3:45pm |
went out this morning and it looks like the rear left has dropped a bit more than the others. in order to check the valve block (?) and inspect for the hairline crack between the 2 pipes - as is the common problem, am i right that the pump is directly underneath the rear passenger door, behind the black face plate?`
Tue Aug 01 2017 4:38pm |
The rear left corner has dropped, that means that you've got a leak somewhere between the valve block and the rear airbag, not the compressor.
Tue Aug 01 2017 4:57pm |
Ok.
Tue Aug 01 2017 5:04pm |
