Home > Technical > Location of front heated windscreen fuses
Adrian,
Fuses Located in Engine Bay Fuse Box, they are in a bank of six fuse located to the rear and slightly left, sort of pink square 30amp rated fuse position 2 is right hand side and six is left hand side.
Have emailed wiring diagram and Service Action Bulletin. the torx screws do have locking compound on them but shouldn't be that tight as only retain a bit of trim. Laughing
Post #531243 Wed Jul 26 2017 8:38am
Bill Portland
Cheers for that Col, I've just replied to you by email.
For others benefit, this is what I said "I did some investigation last night and it looks like one of the 2 30amp fuses has blown. It's difficult to be sure, cos I cant get the bl00dy thing out!
It's one of the J Case fuses mentioned in that .pdf, about 10mm square box with "30" on the top. One of them has nice shiny metalwork inside, the other looks like dull and broken metal.
Silly question, how do you remove/replace that type of fuse? I grabbed at it with long nose pliers and pulled, but no luck." Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #531245 Wed Jul 26 2017 8:44am
Pillars should remove. Maybe it got hot.
The top windows do pop off though. For inspection
Post #531255 Wed Jul 26 2017 9:32am
shepp
The fuses are very stiff, but you can also pop the top off and check for continuity from one half to the other. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #531273 Wed Jul 26 2017 12:37pm
Bill Portland
Just pulled it out with a bit of a pull and wiggle.
Definitely blown. Off to Halfords later to get a new one (doesn't seem to be any spares in the fusebox). Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #531275 Wed Jul 26 2017 12:48pm
I'd get the side trim off before you replace the fuse and disconnect the windscreen if easy.
Don't want to just blow another fuse straight away at halfords prices!
or at least if the screen is disconnected and it blows, it will give some clues
Post #531321 Wed Jul 26 2017 6:10pm
Bill Portland
Halfords only stock the full size ones, not the low profile ones. I've ordered a couple from Rimmer's.
I suppose I could swap the l and r fuses just to see. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #531325 Wed Jul 26 2017 6:25pm
