![]() | Home > General > what I need to know to get towing |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
Pop off the rear tow cover (middle of the back bumper) and see if you have tow electrics. If so, all you have to do is buy the tow hook, assuming you have lifted the boot floor and there isnt a tow hook under there?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5103 ![]() ![]() ![]() |
It is possible to cheaply diy fit electrics. See a sticky thread.
Thanks everybody, i'll whip the cover off tonight. Already checked under the boot cover and there is no tow bar, plus I'm an old fart so old school rules apply |
If you saw fuses under the boot cover you should have electrics |
If you can follow instructions and like a bit of saturday morning fun buy a dedicated kit and fit yourself and then buy said tow bar off ebay or similar you can pick up the kits for about £70-90 as i did for mine and works great and its a 13 pin for towing me tin tent |
Took the bumper cover off last night, one of the clips sheared (doesn't look like its ever been disturbed) and there are no electrics = 2 gaping holes.
Clips here on ebay
Thanks very much again, i'll look tonight as my work computer won't allow ebay |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
DIY Instructions - done by another old fart
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
What sort of towing are you planning to do? If you plan to tow a caravan or similar on a regular basis, consider a more robust tow bar. LR do a fixed version or you can get well made kit from Tow Trust.
and here are the tight electric version (if you aren't going to use it much )
Again thanks everybody for the advice and help. It will be an occasional user for a trailer, it just seems that now we have purchased a most capable vehicle and the history of the brand that it is not fitted to tow from the get go. Anyway wheels are in motion so to speak |
