![]() | Home > In Car Electronics > REVERSE CAMERA INSTALL |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
are you sure it's a button and not a remote control receiver ?
veritas200700 Member Since: 22 Jul 2017 Location: Bradford Posts: 9 ![]() ![]() ![]() |
It's definitely a button which can be pressed
That does look look very similar to button that came with a GVIF unit I fitted into my old 09 plate sport, can't really remember fully but sure it was used to change the view on the screen, sure there were three different selections, tv, rear screens and possibly camera or audio dispay as I say can't really remember.
When the button is pressed it definitely makes a noise below the passenger seat, upon investigation I've found a few modifications there. I've taken some pics to see if that helps to identify what is there.
It's not a gvif unit but similar to one but it also has some parts missing it looks like |
It looks like it has had a playstation in there at some point as well as the loose power supply lead looks like a ps2 power lead |
Thanks for that. Was the PS2 used as a DVD player you think? Or is Sat Nav unit used as a DVD player?
My playstation was used as a dvd player as well not sure if your feeds from that unit go to the screen or not you would need to find that out by removing the screen at the front and seeing if there is a fakra connection made at the rear of the unit and also if the unit is capable of taking a reverse camera |
