![]() | Home > Maintenance & Modifications > OSRAM Nightbreaker Unlimited Xenarc Bulbs |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9066 ![]() ![]() ![]() |
I've been using these for some time now. Definite improvement when driving on lanes at night. 2012 SDV6 - it's missing a couple of cylinders
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 206 ![]() ![]() ![]() |
Same here and also replaced the halogen main beam with a higher color temperature to match the xenons. 2018 Telsa MS
Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33 ![]() ![]() ![]() |
Puslinch don't suppose you're able to link the main beam bulbs you have? I'm looking for some that will match the xenons colour |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I run PIAA Xtreme White high beam bulbs. They match the low beam perfectly in colour. |
From memory it was Osram H7 4,200k xenon look from Amazon. Gary 2018 Telsa MS 2012 Range Rover Sport HSE+ 1990 Porsche 944 1985 LR 90 Soft top V8 |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
Links??? URLS???? pics????
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Have a peep at this thread: http://www.rrsport.co.uk/forum/topic46312.html
The problem with using LED bulbs in a closed environment (which is the case with the RRS headlamp) is that the fan driven heat exchange function cannot work properly - there is no where for the heat to go in a closed housing. The LED driver gets extremely hot and needs cool air to work properly and give full power. The ability of the unit to operate effectively and over a long period of time will be dependant on how long the lamp is operated continously. If you use it for short periods of time intermittantly it may not be a problem. I don't know of anybody who uses an LED bulb in a low beam application within an enclosed housing for the above reason. Bulbs using a weatherproof seal such as HB type bulbs don't generally get installed within a sealed enclosure, similarly H4 LED bulbs generally use the rubber end cap where the bulb passes through a labyrinth seal. In both cases the heat exchanger fan is not within an enclosure.
There are MANY high power enclosed LED units on the market. Mainly light bars, but OSRAM do an LED fog light replacement, the main reason that the big names don't do LED H7's etc is because there isn't a way to replicate the light in the same position as a filament bulb, so your beam pattern suffers. Also, non of the replacement LED units are E marked so technically they're not road legal (in the UK). I only use them as high beams so I don't dazzle other drivers.
