![]() | Home > Technical > 2009 3.0 TDV6 engine fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4503 ![]() ![]() ![]() |
Has it recently has the cam belt and HPFP belt replaced?
Stretch Member Since: 10 Jul 2017 Location: Scotland Posts: 14 ![]() |
Yeah, at only 10k since a new engine i haven't stripped it down to inspect but as it's fine once settled im taking the timing as being ok. |
Hi all,
I think if it was my car I would drop it off with Mikey, he is only about 50 or 60 miles away from you. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Were they new Or used injectors? |
Used, they came out of a Disco 4 same year same engine with lower mileage (that i had access too |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Sometimes it's the simple things!
What fault code reader is being used? Sometimes, the cheaper generic ones don't pick up all the manufacturer specific codes |
My own Snap on machine running the latest software, Ive scanned it with an Autel though too and that showed nothing. |
I'd be inclined to have it on an IID/Autologic/SDD, just to confirm it's not a manufacturers code not being detected |
It's been on a Land Rover dealership machine, they picked up nothing. Sat in the dealership for 14 days then turned round and said the injectors needed coding |
