Home > General > fog light issue rrs 2007
sport2007
United Kingdom 2010 Range Rover Sport TDV8 HSE Rimini Red
hi all
I fitted a reversing camera some time ago with the media interface all is working correctly, buy I have since found out that the fogs have stopped working at the rear only. the only wire I tapped into was the green wire to the reversing light. I had the rrs in at dealers for something and asked him to check probably just a fuse I thought buy he said it was the wrong wiring harness and the disconnected the camera and they worked fine.any one any ideas all fuses in front and rear boxes ok.
thanks
phil
Post #530410 Sat Jul 15 2017 2:34pm
fog light fuses behind the glovebox
does the dash orange light come on ?
Post #530415 Sat Jul 15 2017 4:50pm
sport2007
Yes
Post #530419 Sat Jul 15 2017 5:26pm
geoffsnook
that sounds like something to do with the towing side of things as when you have a caravan connected the fogs do get turned out but not to sure how you would have done it or which wire you spiced into Thumbs Up
Post #530447 Sun Jul 16 2017 8:59am
sport2007
Thanks will have another look and see what happens
Post #530452 Sun Jul 16 2017 10:02am
do you have an aftermarket towbar electrics then ?
Post #530453 Sun Jul 16 2017 10:10am
sport2007
Yes but it's the Range Rover plug and play no fiddling with wires.
Post #530454 Sun Jul 16 2017 10:13am
