![]() | Home > Technical > Crashey ride |
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254
Maybe get the wheels rebalanced first? Cheap one.
| dalmat Member Since: 09 Sep 2015 Location: Split Posts: 36
I agree with Hemo, check the wheels. Mine are genuine 20'' and during last swap from winter to summer tires, it was obvious that one wheel had small dent from inside, I was not aware of that. RRS is a heavy vehicle so even slight hole could cause such thing. |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
I'd get the balancing and alignment done for starters, but it won't cost you £150, should be no more than £60 even if they have to adjust from and rear.
| Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259
Thanks for the suggestions, will start with balancing and alignment, does the vehicle have to be put in tight tolerance mode for the alignment, be interesting to see if the garages know this, had a quick look on the alignmycar site, most of my local ones appear to be bodyshops or there is an Ats euromaster which offer the before and after printouts, 4 wheel alignment for £65 Nanocom Evo |
I believe it does have to be put in the tight tolerance mode, just check when booking somewhere that they know that, if they aren't aware, then I'd chose another place. |
| Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298
Hi Jaggs,
Had the alignment done this morning and it feels better thanks for all the suggestions folks
Good to hear |
| Bowesman Member Since: 18 Oct 2016 Location: Leeds Posts: 14
Hi Jaggs, my 07 Sport is showing the exact same symptoms. Did you have it done in Leeds, if so where did you go. Cheers Pete |
Had it done at Master Cars, Birstall, near ikea, they are a body repair shop with the hunter equipment. Nanocom Evo |
Really close to me, cheers |
Green oval will be close too tnen, good Indy Garage Landrover specialist, if you haven't had the oil pump done on your RRS then I would recommend you do before the tensioner snaps and kills the engine, 2007 are prone for it, I had to have a new engine. Nanocom Evo |
cheers Jaggs, i know Green Oval, will check my service history to see if Oil Pump got done with Cambelt change. My alignment was way out (see image) and sorted thanks to Master Car, still got an issue with rough steering and DSC. Forum suggests it could be rear bushes or steering pump fluid. But Alignment issue was a good catch thanks to you, Master Car tech said i would have wreck my new tyres if i continued driving as was. |
| All times are GMT |
