![]() | Home > Wheels & Tyres > Overfinch Rims |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
As I understand it you shouldn't put anything bigger than a 19 on a 2005 unless it's got dynamic response and even if it does only 20" then.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5096 ![]() ![]() ![]() |
I would be cautious as you may find they are Overfinch fakes, as they appear to have Range Rover on the centre cap and unless things have changed genuine Overfinch centre caps are something like 71mm dia. and L/R-R/R one's will not fit as they are something like 62mm dia. and will fall through. They may well be cheap Chinese copies.
Genuine Overfinch wheels also come with Overfinch and not Range or Land Rover logos on the centres IIRC. That design is called the Tiger and hasn't been sold by Overfinch for a few years now - it was also available in 20" if you like the design but don't want to run on 22's. So anything "new" will be either a refurbed set, old stock or a copy.
Neilradders Member Since: 09 Jul 2017 Location: Wolverhampton Posts: 5 ![]() ![]() ![]() |
Thanks very much chaps .. I will be taking your comments on board.. |
