Home > Faults & Fixes > Starter solenoid clicking
Rainboy
Scotland 2005 Range Rover Sport Supercharged Santorini Black
Hi all,I seem to have picked up an intermittent fault with my 2005 s/c sport,starter just clicks when turning the key,I have a new battery and the system is charging,tried in park and neutral,it's been going on for a few weeks,it's been good for a couple of weeks but failed again today,it did eventually start though,starter or relay issues?,I'm confused😫
Post #529565 Tue Jul 04 2017 5:12pm
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Poor connection, check the earth cable including engine to body is secure.
Post #529567 Tue Jul 04 2017 5:35pm
Rainboy
Will do,thanks for ur help,cheers👍🏻
Post #529571 Tue Jul 04 2017 6:17pm
Paddi
Had the same issue on and off for weeks. At the same time the front parking sensors were intermittent and 'phone sometimes failed to pair on starting up. After a while all returned to normal even though I had not found the fault. Then the alternator failed. I can't help thinking the faults were in some way related to the alternator going bad. It was a diode that had blown up.
All good now Thumbs Up 2008 MY Java Black TDV8 HSE
Post #529615 Wed Jul 05 2017 12:39pm
Mine did that when the starter was on its way out. New starter cured it, obviously. 2012 SDV6 - it's missing a couple of cylinders
Post #529618 Wed Jul 05 2017 2:34pm
Rainboy
Hi,thanks for all of ur answers to my problem,my front parking sensors have also been playing up so I will get the earth strap checked and maybe just replace the starter😫,thanks again👍🏻
Post #529628 Wed Jul 05 2017 4:57pm
