![]() | Home > General > Dynamic Response Control |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2020 ![]() ![]() |
Look for the additional reservoir under bonnet on left with yellow cap. Embossed on cap is a car with an arrow either side to denote roll. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
According to the sales brochure for Q3 2009, ie for 2010MY facelift cars, the TDV6 HSE has Dynamic Response as standard for UK spec cars. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Wouldn't be so sure Tim. I have seen a couple of HSE models without DR |
Chunk11 Member Since: 02 Jul 2017 Location: Manchester Posts: 47 ![]() ![]() ![]() |
Okay thanks for your speedy replies guys and good news my car does have dynamic response. |
Good news better handling yes, but bad news when the bars start leaking ££££'s 2008 G4 RRSport TDV8 current
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
Was it normal to still have the switch to turn off stability control even if it wasn't fitted? I have a 2005 HSE I don't have the active bars, or reservoir, but the icon on the dash lights up then goes out, and it has the switch that activates the light on the dash, and the message centre says stability control off. There's no evidence of it being fitted and removed at any time. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
Stability control is standard across the range. This is DSC for Dynamic Stability Control and is switchable by the driver from the dashboard. Note that it never fully switches off when the button is pressed.
Oh ok I was confused, I thought they were the same. Thank you for clearing that up for me. |
DSC is a safety device that,IIRC, is now required to be on all cars - it is supposed to cut engine power when it detects severe steering inputs, throttle inputs and/or heavy braking and reduce the chances of an accident...... There are circumstances like in mud or deep snow when you need to over-ride DSC because you want to keep power on when making severe steering inputs and not have the computer intervening. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks for the explanation, I often wondered what it was, never had it on the D2. |
