![]() | Home > Technical > 07 TDV8 - Front ACE leak or something else? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
Might be wrong here but surely the Fluid Level you need to check is the Dynamic Response Reservoir not the PAS, but happy to stand to be corrected.
marzman Member Since: 20 May 2013 Location: Cheshire Posts: 9 ![]() ![]() ![]() |
Thanks for your response, but i'm pretty certain they're the same reservoir. Would be delighted to be wrong though! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
They are separate reservoirs. One by the FBH is the PAS, one by the air filter box is the DR. Both have yellow caps but with different logos on them. 2012 SDV6 - it's missing a couple of cylinders
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
Same fluid I believe but definitely different reservoirs as said Nanocom Evo |
Great, thanks guys. |
