Home > Faults & Fixes > Fault
Daver
Fault
My 2007 2.7 has just gone into limp mode HDC gearbox park brake and limited gears turned engine off and started again but with in a mile it happened again what I noticed it doesn't happen the faster I drive could it be a battery issue I work away Monday to Friday so it's not used
Post #529134 Tue Jun 27 2017 1:04pm
geoffsnook
Yes it certainly could you need to check the battery voltage with the engine not running and then start it up and see what the voltage changes to Thumbs Up
Post #529160 Tue Jun 27 2017 4:28pm
Daver
Thanks mate me mate works for the RAC get him to check it for me 👍
Post #529161 Tue Jun 27 2017 4:33pm
DrRob
Stick it on a ctek charger via towing electrics (if fitted) when it's parked up Thumbs Up
Do a search on here for ctek and all will be revealed. Do the same on Disco3 sister site Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #529177 Tue Jun 27 2017 7:55pm
