![]() | Home > General > RR51 SCR (Range Rover Sport SuperChaRged - worth anything? |
It will be worth something to someone how much would you look for it |
You could put the plate on retention and transfer it to your next car - if the plate has a year letter or is of the current style then you have to watch that the plate isn't more recent than the car you are putting it on, i.e. You mustn't make the car look younger than it really is. If you remove the plate for retention/ sale then DVLA will issue a new age related standard plate for the S/C unless it was on a standard plate before you put you private one on, in which case the number will revert to that. Don't forget to tell your insurer though if you change the plate........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
robmeister1969 Member Since: 24 May 2008 Location: Surrey Posts: 128 ![]() ![]() ![]() |
Thanks - just had a look online and it looks straight forward enough. £80 charge.
