Home > General (L494) > 3 Year Old - Leaking Diff
PauloAmore
Scotland
Hi there,
Just had my 3 yr service and have a leaking rear diff deal.
Was quoted £950 for the repair though was completed under warranty. All good right..
But the more I think about it though. I ok'd the repair at 0900. The dealer had the car for another 5 hours. How does one get a quote of £950?! One hundred quid an hour plus oil? Can that repair even be done that quickly. I'm thinking about disconnecting the driveshafts, dropping the diff. New seal. Oil. Reverse.
Thoughts?
Regards
Paulo 2022 P440e AB
Post #528890 Sat Jun 24 2017 8:59am
Tim in Scotland
I believe the leaking diff is relatively common on L494, I have patches of oil on my gravel drive that are either at the back of the RRS or the front of my Defender............... Def I know drips oil but not sure if it is the RRS diff. The car was serviced in May and no remarks were made by the local LR Dealership who carried out the service so have to assume it is the 90 that is marking its territory! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #528894 Sat Jun 24 2017 9:53am
wilf
£100/hr is way below normal main dealer labour rates.
Try more like £150/hr. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #528921 Sat Jun 24 2017 4:26pm
Black Bess
My 2014 had a leaking pinion seal on the rear diff when I bought it 4 months ago. Manifested by drips on my drive within a couple of days.
It seams to be really common. And dealers tend not to fix it in pre-sales preparation because that costs them money. That is why they wait for you the customer to complain and then charge it through the warranty scheme and make money !
No need to remove drive shafts, but you do need to drop the prop shaft. It is not such a good lash-up under there as the old L320.
Post #529036 Mon Jun 26 2017 12:31pm
BigBen
Just had my L494 RRS serviced today at exactly 3 years old so now out of warranty. Dealer found leaking rear diff and it will be fixed under warranty ( as I had booked it in prior to expiry). Only weeping so no sign on floor of oil. It seems it is a known problem from what I was told.
Post #529074 Mon Jun 26 2017 5:08pm
PauloAmore
Scotland
Thanks chaps.
Still...
Seems like a sore one for an out of warranty repair. Nearly £1k after all. 2022 P440e AB
Post #529106 Tue Jun 27 2017 7:20am
Black Bess
Yes my was under warranty. Otherwise, I would have brought it away and done it myself. Smile
I have just spotted that you have a Plus 8. That is far more interesting!!!
Adam..
Post #529108 Tue Jun 27 2017 8:58am
