Home > Technical > Tdv8 grey smoke from cold
Johnsurrey
Hi Iv got a 2007 tdv8 with 49k miles
Problem is when starting from cold grey smoke from 1 exhaust and running lumpy give it a few minuets and it's fine
Any ideas anyone ?
Post #528153 Wed Jun 14 2017 5:30pm
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Possible glow plug issue? Smoke and lumpy due to inefficient ignition when cold but once warm will be fine. Code reader best way forward.
Post #528165 Wed Jun 14 2017 8:29pm
S16ARV
Sounds like egr problem
Post #528179 Thu Jun 15 2017 8:05am
Black Bess
Might be, but if it is only when starting from cold, I would look at glow plugs first. Sounds like one or two have fallen over and you are getting no heat in those cylinders, causing unburnt diesel to be exhausted.
I do not know how accessible they are on the V8, but they can be tested in situ with an ohms meter. Probably best to change the full set though, because once one has failed, others tend to follow suit. Not necessarily a job for a dealer. Any sensible independent could do it if you are not doing it yourself.
Post #528186 Thu Jun 15 2017 10:40am
I seem to remember reading that the glow plugs are prone to seizing in the head. As they are fairly fragile beasties, it's not then unusual for them to snap requiring major work to remove them. Which is annoying because they're fairly cheap items otherwise.
For example:
http://www.rrsport.co.uk/forum/topic34143.html 2012 SDV6 - it's missing a couple of cylinders
Post #528203 Thu Jun 15 2017 2:32pm
Black Bess
Yes, I read that too. It may well be true. If only the engine builders at Ford used a little bit of copper grease on them instead of screwing them in bone dry, there would be no such problems. And less revenue for service departments probably.
Post #528204 Thu Jun 15 2017 2:35pm
Johnsurrey
If it was glow plugs would it do it every time?
Started up this morning and no smoke and not lumpy at all
Started up tonight after work and smoking again
Post #528217 Thu Jun 15 2017 5:40pm
Black Bess
It is difficult to say. It is the sort of fault that is temperature dependent. On the warm days we are having you might get away with a few duff glow plugs, but in cold weather the engine will definitely have trouble starting. I would expect you to have trouble when starting the engine from stone cold, but possibly not throughout the day.
In effect what is happening is the engine is only running on the cylinders where the plugs are working and unburnt diesel is emitted from the faulty cylinders, until the engine gets warm enough or spins fast enough for all cylinders to chime in.
If the misfire ad smoke persisted, it might be EGR valve trouble as others have mentioned. But if it is brief, after cold start, I would suspect the glow plugs first.
Post #528249 Fri Jun 16 2017 8:15am
Johnski
IMO The best first thing to do, would be to get the codes etc checked, either at a LR dealer or by yourself if you have a GAP IID BT unit, this can at least stop you wasting money on things that might be fine. John
Post #528253 Fri Jun 16 2017 9:51am
Johnsurrey
No smoke or lumpy this morning or this evening
Spoke to Harwoods £150+ vat to read the codes , spoke to an independent and said maybe a sticky injector
Post #528326 Fri Jun 16 2017 6:00pm
Johnsurrey
Had the codes read today and no faults
Post #528910 Sat Jun 24 2017 12:40pm
DrRob
Daylight robbery charge for reading codes! I bought my own reader for half that price! Not as good as a GAP IID BT but just shows how they make their money Whistle * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #528916 Sat Jun 24 2017 3:10pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
I had similar symptoms as you in the winter and I suspected it was a glow plug issue. I got round it by cycling the ignition twice before starting the engine, giving the glow plugs more time to heat.
I take it you are waiting for the glow plug light to go out before starting?
Post #528934 Sat Jun 24 2017 4:36pm
Johnsurrey
Didn't go to a dealer , a mates got a garage so he done it for me
Yeah always wait for the light to go out
Post #528951 Sat Jun 24 2017 10:28pm
Black Bess
I fancy that your problem is the glow plugs then, which I suspect have no on-board diagnostics. So no fault code. They are just a coil of resistor wire switched by a timed relay, at the end of the day.
Post #529035 Mon Jun 26 2017 11:22am
