![]() | Home > Technical > Heat seater modules but no switches |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
Well a UK spec HSE would have had heated rear seats as standard.
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
It does indeed doesn't it. also started tow wonder if my HSE advertised car really is HSE. if the car seat charger modules are functional then i will be looking at getting them working - which means the new back facia for the centre console.
You could remove the rear console panel (which is a bit of a pain, but probably worth it) and see if the switch connectors are present.
Thanks. Will try that. Looking at videos for the rear console removal it looks to be a timely job.
So it seems to have taken me over a year to get aroubd to this.
It is a "market specific" thing although surprising in a place that can be pretty cold in winter not to make the rear seat heaters standard. Way back in the 1990's when Freelander 1 was sold the base model cars had no aircon as standard but it was a hugely expensive optional extra. One smart forum member found that in fact ever Freelander 1 that was built for the UK market roiled off the production line with a full aircon system fitted. After delivery all you needed was a 25p switch to have fully working aircon and many people were robbed of about £999.75 for factory fitted a.c when spending 25p would have got them the system! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Amazing. Thats what one of the 'petrolheads' newrby said. It seems the cars are built with most of the extras. Ht in my case i'm missing the actual on and off switches. And maybe the cff files. 2019 RRS P400e Autobiography
The green plug looks like aux audio input.
thanks.
Cant believe it has no rear aux or cigarette lighter sounds as though someone has changed bits and not with the same those 2 wires do look like the power for the cig lighter and the other for the aux |
think we been round this before.
clearly.
