![]() | Home > Technical > Revisited 2007 "7A" TDV6 EGR BLANKING. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
Done quite literally, hundreds of EGR blanks on 07/08/09 models, and never had an issue |
Same here, as long as it has the right software patch applied, you won't get EML appearing for an egr fault.
Oh and you don't have to have working egrs to blank them. The only people that tell you that you do are the cheap generic remappers that can't map them out properly...... Bodsys Brake Bible
Terrye Member Since: 20 Jun 2017 Location: Wales Posts: 9 ![]() ![]() ![]() |
Thanks for the reply gents.
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
My RRS is 2005 so did not need the software patch. I bought the kit from ebay for about £15 and fitted it myself. It was a bit fiddly as the egrs are situated fairly low in the engine bay but a pretty easy job really.
Cheers mate.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
I have an O7MY and my egrs failed back in 2011 - before emulators. I bought two new EGRs and a BAS blanking kit - and remapped the ECU with the BAS version. As part of that process and before fitting the new EGRs I participated in an early remapping trial by BAS that included taking the EGrs out of the system - an early emulator.
Very easy solution with no hassle = Bodsy is mobile and can do it all for you and you will be assured it's done properly. Job done |
Cheers Dr rob.
Spotted and emailed. ![]() Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Many thanks to bodsy who came down to my house the very next day.
No problem, Great to meet you and have a chinwag. |
