![]() | Home > Technical > Active roll control module fault |
Nico2104 Member Since: 10 Jun 2017 Location: Derby Posts: 58 ![]() ![]() ![]() |
1st check that you don't have a lamp blown in the rear light clusters.......... a failed brake light causes all sorts of totally unrelated warning lights to come up on the dash 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
2nd, check that the module plugs are fully inserted. A loose wire will throw all manner of issues. If someone has tried disconnecting the plug for any reason, they may have pulled on the wires. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
3rd, report back with actual fault codes from ALL modules |
typhoo12 Member Since: 10 Nov 2016 Location: United Kingdom Posts: 40 ![]() ![]() ![]() |
How did this one get settled? |
It was the actual arc ecu. Had it replaced and now is all good. Thanks |
