![]() | Home > Wheels & Tyres > What 19 inch rims will fit RRS with Brembo brakes |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5069 ![]() ![]() ![]() |
Part No. for this wheel is LR014979 I think maybe Style 5
Cheers Col |
These are top picture RRC002900MNH Bottom Picture RRC502280MNH
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Cheers guys. Hopefully getting somewhere now. Robin
Hmmm. I'm starting to doubt myself now. But what else could it have been that meant my wheels fouled the brakes? I'm rushed off my feet work wise at the moment. Hopefully it will get easier in a month and I can have a proper look.
The problem isn't the discs it is the calipers casing - there are two black plastic covers that stick up from them and they foul the wheel IIRC. Removal of them unfortunately is a non starter as they are dust caps for something (excuse the technical language!). 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
OK - I bit the bullet today and ventured into Harwoods, Lewes parts dept for a definitive answer |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
Strange. My 08MY TDV8 wears 19 inch rims quite happily over its Brembo calipers. 2012 SDV6 - it's missing a couple of cylinders
As did my TDv8 when I had it
AGGGHHHH
I will be going 18" comps PD1881 shortly |
That's interesting Buckster. Had a look at them and noticed this comment:
Phonic dampers are the plastic things I mentioned earlier 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
The Phonic Dampers are the rectangle blocks at each end of the caliper, held on with a allen screw I think. If you remove them you may well get noisy screeching brakes as they are dampers to prevent this, if I understand correctly.
