![]() | Home > Technical > Detachable towbar query |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 ![]() ![]() ![]() |
sorry been away for a while I have a few odd jobs for a friend collecting boat tlr's down to Christchurch to his boat yard and some of them go very heavy on the nose I only tow at an average of 120kg as a rule but the sport was rated at 250kg and I wanted to keep that for the boat trl's JLR have now issued a supplement for the book down rating to 150kg on the detach bar |
Stevieg330 Member Since: 20 Apr 2017 Location: Dorset Posts: 6 ![]() ![]() ![]() |
Hi All,
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 126 ![]() ![]() |
Steve,
RRS nutter Member Since: 10 Aug 2019 Location: Surrey Posts: 1 ![]() ![]() |
Hi M3 DPO
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 ![]() ![]() ![]() |
Love the removable towbar. In NZ the max tongue weight allowed is 350Kgs so quite a bit more than over there. Although I have done heaps of towing with it I did decide to get a security device when I was doing long trip with multiple jetskis due to the value on the trailer.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5113 ![]() ![]() ![]() |
Yeah, had Advanced Factors ship one of those security plate kit's out here to me, cost almost as much to ship as to buy the kit |
Fitting it is different to the UK as we don't have the gooseneck towbar. I had a chain link between the plate and crossmember each side to space it correctly and it also meant I had somewhere to attach chains to still. Also had to cut a wee flat across the green towbar handle to get it in there.
Fortunately no problem fitting to mine, as U.K. spec. A/B which I brought with me when moved here. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Yeah ok I'll bite. Can't see a way for that security plate to fit with the receiver hitch. It's a very different shape to the ball hitch. 2012 SDV6 HSE (technically its hers)
As mentioned a chain link in each side to take up the gap and it gives somewhere to attach chains to.
