Home > General > Drivers seat problem standard type
Triplejjj
United Kingdom 2007 Range Rover Sport TDV6 S Java Black
I've a 2007 rrs 2.7d with cloth interior.....today I bought black leather seats and I've changed them all ,looks brilliant!!!
Only thing I can't get working is drivers seat ...my original cloth seat wasn't heated or memory type.....so my problem is now that the wiring plug Wires are lining up wrong and because new leather seat has more plugs....I'm kind of lost as to where wires go........Anyone know of any diagrams to follow cheers for help...jjj 1st picture is plug on cloth seat drivers 2nd picture is new leather seat drivers
Post #527165 Tue May 30 2017 9:38pm
Tim in Scotland
Sorry I cannot help with the connectors problem but concur with your comments about the improvement of the leather over the cloth - my sister bought a used RRS S (same as yours) and the seller offered her the cloth seats that he had removed and replaced with leather. Depending on the version of the donor car only the seat fronts will be leather if the car was an SE, the rest is extremely leather like plastic leather (ie on the seat backs and bases , if the donor car was an HSE then the seat backs will also be leather. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527185 Wed May 31 2017 7:50am
Triplejjj
Damn.....thinks it's back to drawing board....I will probably strip out bottom connections and rewire it.The seats I got where out of a supercharged rrs....I got door cards and centre fridge too though might not fit fridge
Post #527224 Wed May 31 2017 10:59am
Tim in Scotland
Then you have the most puckah Perforated Leather "Sports" seats that were on the S/C. You would also have to replace the door card as there is an additional memory panel on cars with electric seats that your S wouldn't have, it is also connected to the electrically controlled wing mirrors which I think the S didn't have. I have all the brochures up to present so if you want any interior photos I may be able to scan them and email them to let you see what the different trims and specs were. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527231 Wed May 31 2017 11:46am
Triplejjj
Thanks Tim....I also got door cards here,so going on what you said I will replace these,but not too worried memory or heated seats option.....just want seat to move....Also my rrs has electric mirrors fitted.
Post #527233 Wed May 31 2017 11:53am
Triplejjj
Job complete....stripped out wiring from new leather seat including module and then dismantled my cloth seat wiring loom and transfered side switches and loom to leather seat....Only one problem pink and brown wires had to be cut to enable plug from Upper motor to be changed.Difficult job
Post #527295 Wed May 31 2017 10:24pm
DEVON
Well done with the seats Thumbs Up
And I'll have first dabs on the fridge if your not going to use it Whistle
Post #527311 Thu Jun 01 2017 12:06am
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Look smart mate well done bit of time and patience goes a long way
Post #527313 Thu Jun 01 2017 4:28am
Triplejjj
Cheers I've the whole lot on for 200...Inc fridge there's a few heat modules and memory modules for seats I'm gonna sell seperate
.probably more hassle seeing I'm in Northern ireland Embarassed
Post #527322 Thu Jun 01 2017 7:05am
d-9
How easy was it to remove the door cards?
Interesting thread, I had no idea you could buy a sport with cloth.
Post #527324 Thu Jun 01 2017 7:22am
Tim in Scotland
Yes but many buyers of the S model paid for the optional leather, unfortunately they often didn't also spec the seat heaters that were also optional or the electrically operate wing mirrors. They were not in production for very long and there was a special edition (I think the only factory special edition for RRS) called the Stormer that was based on the S - it was an HST body kitted S basically. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527329 Thu Jun 01 2017 7:33am
They did RRS without electrically operate wing mirrors ? Shocked
I'm sure even the Ford GL's of the 1990 had electric mirrors.
Post #527348 Thu Jun 01 2017 11:39am
Triplejjj
Door cards are really easy ,a few hidden screws to come out 1st then a good pull on frame surround d-9
Just make sure you note where wires go and sizes of screws also when fitting again make sure door surround inner 'push lugs'are in good order
Post #527375 Thu Jun 01 2017 6:42pm
Triplejjj
Thanks
Post #527376 Thu Jun 01 2017 6:43pm
