Home > Technical > Poss torque converter
Camelrock
Poss torque converter probs as getting the juddering on light throttle acc but it's intermittent and don't see any fluctuations in the rev counter, also no fault codes recorded on trans, so is it something else. Checked rear prop centre bearing which is ok.
I would be 100% torque converter if it was doing it regular, got 180 miles with the caravan on the back tomorrow so will see what happens but any ideas welcome. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #525883 Thu May 11 2017 5:58pm
Disco_Mikey
Mine also has the same very intermittent shudder
If I hadn't experienced it more severe in a Disco 3, I wouldn't have noticed it at all. But the 3.6 does also suffer from TC judders
Post #525886 Thu May 11 2017 6:56pm
Camelrock
Just an update did the 180 mile run no problem slight judder once when at low revs near home. On reading other gearbox issues on here everyone seems to get the judder when the car is warming up then seems to be ok, on mine it's the other way round ie perfect on warm up but int judder when fully warm and no irractic revs
Before I change the TC any other thoughts or should I stop whinging and get on with it ! 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #526158 Tue May 16 2017 9:50am
Disco_Mikey
The judder only occurs when the gearbox oil is up to temperature, and the TC is locked
Post #526165 Tue May 16 2017 10:56am
Camelrock
Thanks Mike I did know this but after reading the other threads was beginning to think I'd missed something. Had any experience with Bristol trans, seem to be well thought of on d3 forum or go gen from LR normally go the gen route but just thought I'd ask the question 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #526168 Tue May 16 2017 11:50am
Camelrock
Well that's the torque converter swapped, just got the rear arb to do now. Do you need to remove the rear bumper when lifting the rear body up the couple of inches or so to get the bar out ? As I don't have access to a wsm how do you bleed the system and would the front bar need bleeding as well ? 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #527016 Mon May 29 2017 8:53am
karnic
Ireland
With the torque convertor replaced... has the judder gone?
Post #527119 Tue May 30 2017 1:55pm
Camelrock
Yes seems to have sorted problem, seems abit more responsive as well less slip through the torque converter will be interesting to see if the mpg improves 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #527128 Tue May 30 2017 5:20pm
