Home > Maintenance & Modifications > Aux pump
geoffsnook
Aux pump
Hi my sport supercharged is in the vin range for the aux pump problem when I tow my van I get the restricted performance and the p code that tells me the pump issue I can either recycle the ignition and it's ok for a. It on motorway but comes back .Do I have to change Thumbs Up h the pump or can I just reverse the wires and is there anyway to find out first if it has had the work done thanks on advance
Post #526982 Sun May 28 2017 6:28pm
Just reverse wires.
I guess you might see some bodgry if it's been done???
Post #526988 Sun May 28 2017 7:54pm
shepp
It is recommended it is replaced. Apparently it fails rather quickly after reversing the wires. Check out my gallery. It has the tsb. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #526989 Sun May 28 2017 9:07pm
geoffsnook
Don't quite understand why it would fail if you just reversed the wires to be honest and can't see anything on tsb about reversing the wires or am I just being a bit thick Thumbs Up
Post #526995 Sun May 28 2017 9:43pm
shepp
Hello geoff
The below describes the wiring orientation on the pump connector. (From the tsb (there are a couple so check you are on the correct one 😋
Correct orientation Range Rover Sport (LS) is:
• Black (B) wire in Cavity 1 connected to "-" pump
connection
• Brown and Purple (NP) wire in Cavity 2 connected
to "+" pump connection
Correct orientation for Range Rover (LM) is:
• Brown (N) wire in Cavity 1 connected to "-" pump
connection
• Red and White (RW) wire in Cavity 2 connected to
"+" pump connection
3. If the wires are crossed, use terminal extractor tool
YRW9000010 from the Harness Repair Kit and swap
cavity 1 and cavity 2 wires to the positions indicated above. MY12 RRS HSE
Gone 90
Gone s2000
Post #526998 Sun May 28 2017 9:49pm
geoffsnook
Thanks shep what's the difference between a ls and a lm Range Rover Tia Thumbs Up
Post #527000 Sun May 28 2017 10:52pm
LS is your sport
Post #527006 Sun May 28 2017 11:41pm
geoffsnook
Post #527011 Mon May 29 2017 6:47am
geoffsnook
Thanks everyone for info where is best place to get a new pump Thumbs Up
Post #527052 Mon May 29 2017 3:01pm
shepp
I got mine approx 7 years ago. It was only £119 from Landrover. Which isnt to bad considering its on permanently. I think they are nearer 150 now, but definitely worth checking with the dealers first, I've found loads of parts cheaper from Landrover rather than eBay etc. May be worth giving Duckworth a pm. MY12 RRS HSE
Gone 90
Gone s2000
Post #527070 Mon May 29 2017 7:43pm
geoffsnook
Just pm'd him seen them on the bay for £105 and stated as genuine
Thanks
Post #527080 Mon May 29 2017 8:14pm
geoffsnook
Well just changed my pump and wires still find it hard to believe that this has not been sorted on a 12 year old car it looked at when i started to take it all apart it did actually look like the pump was disconnected Thumbs Up
Post #527563 Sun Jun 04 2017 10:59am
