![]() | Home > General > MY17 - Replacement Windscreen Cost |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9131 ![]() ![]() ![]() |
This is standard rubbish from Autoglass. They always say that insurers won't go with an OEM screen. They do this because it enables them to fit a cheaper screen imported from China or some such place. This boosts their profits, unsurprisingly.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 554 ![]() |
Don't panic.....see my update on this thread....http://www.rrsport.co.uk/forum/topic40602-30.html.....
I had a replacement screen put in by my local LR dealership under warranty last December - Autoglass did the work with an OEM screen bought in by the dealer. Check the dealership price for doing the job before getting Autoglass in. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRS-Si Member Since: 24 May 2017 Location: North Yorkshire Posts: 85 ![]() ![]() |
Who's your insurance company. I had this problem last year when i owned a brand new Mercedes ML. I use Admiral and when making the booking via their autoglass approved number they tried the old trick of "autoglass standard windscreens makes no difference as they quality is the same".
Welshian Member Since: 26 Apr 2016 Location: Staffordshire Posts: 88 ![]() ![]() |
This interesting because my 2013 RRS2 I have just bought from Stratstone had a chip which was repaired before I took delivery. It has since got worst and the car is going in for a replacement which they have agreed to. I wonder if there is any obligation by them to fit a genuine part or will it come back with a cheap screen fitted. Should I check with them before it goes in on Thursday or wait until it comes back? RRS2 HSE Chile Red
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 ![]() ![]() |
Great result in the end!
Great result jd bet you were pleased with the outcome, so am I, mine came back fitted with a OEM screen and looking fantastic |
Bushes aren't usually covered by the warranty. That's why they didn't pick them up. They're now hoping you'll pay for them. But you can point out that they have a responsibility under consumer law to correct the fault. 2012 SDV6 - it's missing a couple of cylinders
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Ask for a copy of the inspection report to see, then you are in a better position to insist on replacement. Just after buying my RRS the park brake failed and after recovery their mechanic sent a video of his overall inspection, pointing out brake disc corrosion requiring replacement (his opinion). My emails to the dealer weren't pulling any punches although polite, and I was accusing them of probably never having carried out an inspection or this should have been picked up. Sure enough the group aftersales manager instructed the dealership to prove the inspection was carried out and guess what, the brake disc corrosion had been highlighted - proving they should have replaced them prior to sale. As I can prove everything, this was Peter Vardy Landrover in Aberdeen - I will never deal with those cowboys again (even walking away from a 'free' service due to my distrust of their standards). Of course I then got new discs and park brake module etc. so a satisfactory end, except I should never have had any issue's in the first place. The thing was, those discs were not really that bad, infact better condition than my other 2 Landrovers it's just the dealers way of conning the unwary to bump profits. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
OK thanks for all the advice, of course I may be overly pessimistic and they will change them with no problem. I have also contacted customer support to see if they are covered under the warranty or if its the retailers responsibility bearing in mind I've only had the car not yet 2 months. Watch this space |
