![]() | Home > General > Ace |
M12UPY Member Since: 03 Dec 2015 Location: Manchester Posts: 81 ![]() ![]() ![]() |
How do I find out if I have ace on my 2010 rrs? I want to replace my creaky bushes |
You should have a bottle in the engine bay with a yellow top close to the windscreen wash bottle |
Just found it cheers ant idea how easy it is to replace the bushes🙈 |
Which ones you looking to change some are easy some are not so easy |
The front anti roll bar ones! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
If you have two yellow topped reservoirs then you have Dynamic Response. If you have only one yellow topped reservoir then you don't. The reservoir by the screen wash is the power steering reservoir and they all have that! The Dynamic Response reservoir is next to the air filter box. 2012 SDV6 - it's missing a couple of cylinders
I have one with a pic of a car with the lean arrows on so I'm guessing yes it has |
Just need to workout how to remove anti roll bar bushes |
