Home > General > Sluggish from a standing start
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Car over the last 24 hours seems to be very sluggish from a standing start.
I can press the accelerator to the floor and it slowly builds up momentum. Once it hits about 30 km/ h the rev counter spikes to 3500 rpm. Then it settles down. From then on any press on the loud peddle is normal.
But from a standing start or slow crawl its slow to respond.
This may be purely coincidental but a friends Classic American car had a flat battery and he need a jump. Cables were attached and whilst he was trying to turn his car over his battery sparked and the negativee terminal 'melted' off from the battery on his car. All ither factions of my car are fine.
Any thoughts
Steve 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #526513 Mon May 22 2017 8:51am
An odd idea, but have you inadvertently put it in to grass/gravel/snow on the Terrain Response settings? This gives a very soft throttle as you have described.
Other than that, you need to check for any error codes recorded since you helped your friend. 2012 SDV6 - it's missing a couple of cylinders
Post #526515 Mon May 22 2017 9:44am
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Turbo actuator sticking!
Post #526519 Mon May 22 2017 10:54am
Disco_Mikey
Typical EGR failure
Post #526520 Mon May 22 2017 11:52am
Pakolainen
Thanks for the replies, so it seems 2 * 90 minutes jaunts up the motorway have set it back to normal operations.
cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #526532 Mon May 22 2017 3:39pm
