![]() | Home > General (L494) > Headlamp Adjustment: Left / Right Hand Drive |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 ![]() ![]() |
Thanks Tim |
As above, no adjustment required from at least MY12 onwards (possibly earlier too) due to "flat beam pattern" as per the handbook. However, you would have Auto High Beam Assist (as your signature says Autobiography) and that does need changing. It is in the "Driving Features" menu and you can choose from "Drive on the right" and "Drive on the left". Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Thanks fkarim, that is probably what I came across previously and thought it was to adjust the headlights rather than the Auto High Beam Assist. Which I am fine with as dips way too late when on Auto in my car so is always switched off.
