Home > General > Bought RRS AB!
Page 1 of 3 123>
sonny007
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Bought RRS AB!
Hi All,
So I've decided to take the plunge and buy the RRS AB TDV6 MY10
here are some pictures. Cool
See last pic with high beam turned on which is halogen. I thought the main beam is used for high beam?
I want to change colour of high beam so it matches the main beam xenons. Same with cornering and foglight.
List of mods to do-
- Colour code door handles
- Change number plate and interior lights to match ambient ice white colour
- Mud guard removal?
- Secure rear lights (can someone help me with this?)
- Remap? would it be worth it...
Post #526271 Wed May 17 2017 9:15pm
Darbs
Hi, looks great Thumbs Up
Post #526273 Wed May 17 2017 9:38pm
Tim in Scotland
Congratulations - what sort of warranty does it have? Standard 3 months non-franchised dealer warranty? I would suggest you drive it for 3-4 months before you decide if it needs a remap.
Headlights, only the dipped beam are Xenon on most cars but the mains can be upgraded with new lamps giving a whiter light and (if you feel you need it longer range) - I have had the Bi-Xenons on two RRS's (L320 and L494) and find them more than sufficient for fast driving on the local country roads I normally drive. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526274 Wed May 17 2017 9:40pm
sonny007
So my one isnt bi-xenon? RRS Autobiography TDV6 MY10
Post #526276 Wed May 17 2017 9:47pm
sonny007
I have 12 months warranty with company I bought it off. first 3 months they'll cover everything and after that they cover main components. test drove car and notice slight vibration on steering and they changed brake discs within 2 hours. RRS Autobiography TDV6 MY10
Post #526277 Wed May 17 2017 9:49pm
Tim in Scotland
IIRC The lamps with the magnifiers are the Xenons - some folks call them "projector" lights. BTW the "signature" LEDs are not Daylight running lights on your car, the LEDS will only come on when you run with dipped headlights but it is possible to modify them - search in the forum as it has been covered. One suggestion - take the VIN into a main dealer service bay and ask them to check for outstanding recall work and TSB's that might not have been carried out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526278 Wed May 17 2017 9:55pm
sonny007
i'l check out the DRL. messaged peachy today and he checked that there is one outstanding recall which was TOW BALL, but this car didn't come with one RRS Autobiography TDV6 MY10
Post #526279 Wed May 17 2017 9:58pm
Tim in Scotland
It may have been removed by the garage - there is a thriving market on eBay for them - to check, look in the middle of the rear bumper and if there is a removable section in the middle, take it out and see if there are electrics installed - at the very least there will be a whacking great cast in recovery eye, if there is a slot for the removable tow hook and electrics then the dealer owes you a tow hook! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526281 Wed May 17 2017 10:02pm
PEACHY
Bottom right - No electrics or tow ball according to Topix Thumbs Up 16MY Estoril Blue SVR.............
Post #526282 Wed May 17 2017 10:16pm
sonny007
very annoyed that lr didn't make led drl bixenon as standard!
how can I change led so they can be drl? RRS Autobiography TDV6 MY10
Post #526284 Wed May 17 2017 10:42pm
Pufftmw
Welcome to the fold Thumbs Up
LED Headlight bulb discussion here and there's a how-to & a couple of good choices - I have the second set reviewed by Socast and they are excellent
http://www.rrsport.co.uk/forum/topic46312.html
Post #526286 Wed May 17 2017 10:47pm
Yes, it is bi-xenon. The xenon lamps are used for both dipped and main beams - that's what bi-xenon means.
The halogen lamp is a "fill in" lamp to ensure a more uniform beam pattern when main beam is selected. This is easily "upgraded" to a whiter light output if you wish. 2012 SDV6 - it's missing a couple of cylinders
Post #526290 Wed May 17 2017 11:12pm
sonny007
Yes I have noticed the projector light output increases when flashing high beam, but the halogen side ruins the look! Any recommendations on which light would go perfectly with the Xenon's?
Also, the led dots, how can they be programmed to be used as DRL? Currently they aren't as bright with sidelights switch on?
Don't know if it's a settings fix or something more Shocked RRS Autobiography TDV6 MY10
Post #526293 Wed May 17 2017 11:23pm
sonny007
Here is warranty information
Post #526294 Wed May 17 2017 11:25pm
They cannot be changed in the CCF files to come on alone as DRL's, they can only be programmed to be used in conjunction with dipped headlights when ignition switched on irrespective of position of headlamp switch.
I did previously add a post of the options available in the CCF but not sure when I posted it.
Post #526295 Wed May 17 2017 11:37pm
Page 1 of 3 123>
