Home > Maintenance & Modifications > Does anyone like not having a dipstick for the engine oil
pinemarten
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I can understand having a electonic warning the oil is running low but the only way to check your oil level by eletronic means not keen. How do you know what the oil is like? How do you check your oil level if the sensor becomes faulty. Or is there a way to check the oil manually that I havn't found yet. Had my RR sport just over a month and love everything so far apart from the no dipstick.
Post #526184 Tue May 16 2017 1:29pm
Tim in Scotland
I think you will find 99.99% of members here would much prefer to be able to manually check their oil from time to time and not have to rely on a sensor - we all know how notoriously unreliable sensors can be............ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526196 Tue May 16 2017 3:31pm
Tim in Scotland
Oops double post 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526197 Tue May 16 2017 3:32pm
Its a diesel. The oil will be black
Post #526208 Tue May 16 2017 5:46pm
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
I prefer a dip stick every time. I once had a rover 825 sterling. This had both the dip stick and a sensor, when I purchased the car, the sensor showed low oil but on the dip stick it was full. Sensor replaced (sump off) and it was fine, for 3 months then back to the same again. Very unreliable, the only reliable way is visual inspection.
Post #526212 Tue May 16 2017 6:46pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
You need to see the people who buy these Zara new, majority wouldn't open the bonnet for the three years they own it, certainly not mess about with dipsticks.
For them, a sensor is much better in between getting the dealer to service the car.
As for evoque women drivers..... Rolling with laughter Rolling with laughter Rolling with laughter Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #526213 Tue May 16 2017 6:58pm
Disco_Mikey
All good and well, but surely the car should tell you when the oil is low, to prompt you to top up, instead of running itself dry of oil Rolling Eyes
Post #526215 Tue May 16 2017 7:26pm
Quite.
Bet mist owners don't bother to check or don't know how to.
Post #526216 Tue May 16 2017 7:58pm
pinemarten
Dipsticks
Thanks for all your replies. In answer to some of them. I know the oil will be black, I want to know where it is on the dipstick, I want to know how quickly it runs off the dipstick. Most of all its fool proof. I know many people wont check them and I suspect they wont check them electonically either. That's there choice. I would like the choice of checking my oil manually.
Post #526222 Tue May 16 2017 8:56pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
It should be both.... One as a fancy shmancy feature to cater to the vain and the other as a functional and fool proof redundancy.
Post #526253 Wed May 17 2017 12:24pm
CANROVER
My 02 Audi A4 had an oil level sensor if it got too low and a dipstick. Perfect combination if you ask me.
Post #526254 Wed May 17 2017 12:26pm
d-9
I definitely like having a dipstick, relied upon the sensor on one of my audis and when I serviced it, discovered the low oil sensor wasn't working and it only had 2.6l in it. It should have had 6.5l.
For the record, when you check the oil with a dipstick, you are normally checking the level, not the colour Laughing
Post #526285 Wed May 17 2017 10:46pm
Tim in Scotland
But with a diesel the colour also helps indicate the level as you can see the level easily. My 1st RRS had a stupid PSA style dipstick with several yellow beads on it - one of the beads dropped off and was never found.............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526303 Thu May 18 2017 8:32am
d-9
Very true, it's particularly hard to see the oil level of a petrol at night with clean oil in it, something about artificial lighting makes it go invisible.
That plastic bead either came out with an oil change or got picked up in the strainer, they collect a lot of crap.
Post #526312 Thu May 18 2017 10:55am
