![]() | Home > Technical > parking sensors |
| Macca Member Since: 03 Oct 2016 Location: Nottinghamshire Posts: 17
Could be one or more of a few causes, most likely place to start is faulty sensor, check if all are 'ticking'...could be internal short of a sensor, if no joy there check the wiring a few good read ups on here.If you have, or can get access to an IID tool or similar would certainly help pinpoint. Ive had both a faulty sensor (easy to find) internal short on one (not so easy) Good luck |
| Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394
thanks , just been out and started the car up put it in reverse and seems to be working fine now , god knows whats going on there. but thanks anyway |
| KernowRRS Member Since: 22 Oct 2016 Location: Cornwall Posts: 20
Wet weather is not nice to the sensors, also apparently jet washing does them no favours |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
I concur with Kernow. I have intermittent (annoying) fault with mine which manifests itself after driving in wet weather Robin
You would think something like Rain would be factored into a parking sensor! |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
Some systems give an error tone if there is a problem when you first select reverse.
cheers for the info guys |
Just for clarity, and in case it's of use, the parking aids on mine have 3 tones. High pitched bleep means front sensors give picked up something, a lower pitched bleep is the rears. If you get a continual high tone for about 10 seconds and then the parking aid switch light flashes, then that's telling you that they are not working.
I think you do get both tones on early cars.
| jakoh Member Since: 29 Oct 2015 Location: SD, CA Posts: 4
How do you find one with an internal short? My front beeps all the time, my guess it is a short. if connector is loose will that cause a always on beep? |
A short would knock all of them out and incase of the fronts give an error on the dash. |
problem statement, front always beeps regardless.
water can also get into the sensors.
Got it, i will buy a sensor and proceed.
| All times are GMT |
