Home > Maintenance & Modifications > Suspension Fault RED had to drive over 50kph for 20 mins
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Hi guys,
Got the infamous suspension fault on the way to work today and was on the high way so I could not slow down. When I finally had a chance to pull over and do a walk around, all 4 sides had lowered to the bump stops and yes it was an extremely bumpy ride. When I turned the car on it all went away magically and the car seems fine. Because I have had this fault before I didn;t think much of it until I was on the high way and then I realized it was a bit more serious than just a max speed warning and a red triangle. I had no choice but to soldier on until I was off the highway. the only thing I noticed was a burning smell coming from the rear but so far nothing has come up.
Has anyone run into this situation before???? Any issues afterwards?
Cheers and thanks
Post #525578 Mon May 08 2017 12:30pm
Socast
Not sure what the issue is (would be best to get the codes read) but for future reference if you knock the gearbox into neutral you can re-start the engine while still rolling. That way you can hopefully reset the system and be not have to limp dangerously up the highway Thumbs Up
Post #525581 Mon May 08 2017 12:47pm
CANROVER
Thanks Socast, DONE!! Here's what I got:
L320 - Range Rover Sport 2010
Vehicle scanned on 08-05-2017 07:48
Using IIDTool BT V3.0 B2444
ABS-Brake Module
U0421-68 (2Cool Invalid data received from ride level control module - Algorithm based failure - event information
( on 08-05-2017 05:23:06 at 97995 km )
ARCM-Active Roll
U0421-68 (2C) Invalid data received from ride level control module - Algorithm based failure - event information
( on 08-05-2017 05:23:07 at 97995 km )
BCM-Body Control
C1A57-14 (6C) Front left initiator - General electrical failure - circuit short to ground or open
( on 05-05-2017 15:45:03 at 97810 km )
B12C9-88 (2Cool Local interconnection network bus E - Bus signal/message failure - bus is off
( on 06-05-2017 14:02:33 at 97958 km )
FEM-Navigation
U2101-00 (2F) Control module configuration incompatible
( on 08-05-2017 07:40:26 at 98009 km )
HCMB-Headlamp
U0415-00 (2Cool Invalid data received from ABS control module
( on 06-05-2017 09:45:18 at 97901 km )
HVAC-Ventilation
U0422-86 (2F) Invalid data received from the body control module - Bus signal/message failure - signal is invalid
( on 05-05-2017 15:37:21 at 97810 km )
U3000-55 (2F) Control module - System programming failure - is not configured
IPC-Instrument Pack
B1A85-96 (2C) Ambient light sensor circuit - Component failure - internal failure
( on 07-05-2017 20:11:10 at 97991 km )
PBM-Parking Brake
U3000-4B (6Cool Control module - System internal failure - over temperature
( on 06-05-2017 12:46:01 at 97950 km )
PDM-Passenger Door
B110B-11 (6C) Rear door passenger side central locking motor - General electrical failure - circuit short to ground
( on 05-05-2017 15:48:00 at 97811 km )
RLM-Suspension
C1A03-92 (6C) Front left height sensor - Component failure - performance or incorrect operation
( on 08-05-2017 05:24:09 at 97996 km )
C1A04-92 (6C) Front right height sensor - Component failure - performance or incorrect operation
( on 08-05-2017 05:23:55 at 97996 km )
C1A06-92 (6C) Rear right height sensor - Component failure - performance or incorrect operation
( on 08-05-2017 05:23:32 at 97995 km )
C1A07-62 (6C) Cross articulation - Algorithm based failure - signal compare failure
Post #525595 Mon May 08 2017 3:11pm
Socast
That's quite a list..
Looks like it Censored itself and decided that 3 of your ride height sensors weren't right..
So it could be that the control module is on the way out, a worn wire that's earthing (I did read somewhere either on here or the American forum that a chap had a similar issue and he traced it back to a worn wire running from one of the ride height sensors, well worth a search as he had images of where the wire had broken/worn) and causing the issue or it could be as simple as the battery needs changing.
Out of curiosity what was the weather like ? Had it rained the night before or during your commute ?
Post #525604 Mon May 08 2017 4:53pm
CANROVER
Very good question and there may be a connection there... It has been raining non stop for the past few days to the point where there is massive flooding all over Ontario. Ottawa hasn't been hit too hard but I'm rambling. Needless to say I see how you might be thinking that all this moisture is creating an onslaught of electrical issues.
Aside from checking under the car for worn wires and such, is there anything else that can be done before I drive this thing through the dealership and shoot myself?
My next moves are going to be fuses, then get under the car and have a good look around.
Post #525606 Mon May 08 2017 5:18pm
CANROVER
Update:
So I finished work and had a look at the car. Driver's side is higher than the passenger side. Got in and lopsided my a$$ back home and used the IIDTool to re calibrate the height. It was quick and easy and it seems to have worked but I can't see this "honeymoon" lasting. I ran the codes after the re calibration and a brief test drive and here is what came up.
Vehicle scanned on 08-05-2017 18:40
BCM-Body Control
( on 08-05-2017 17:57:28 at 98010 km )
FEM-Navigation
U2101-00 (2E) Control module configuration incompatible
( on 08-05-2017 17:57:11 at 98010 km )
HVAC-Ventilation
( on 08-05-2017 07:49:27 at 98010 km )
Post #525658 Tue May 09 2017 1:19am
Socast
Might've been as simple as a re-calibration haha Laughing
Fingers crossed Whistle
Post #525678 Tue May 09 2017 9:33am
Suspension on the bump stops is what happens when the suspension thinks it's got a cross articulation error. Calibration sorts that - been there, done that. 2012 SDV6 - it's missing a couple of cylinders
Post #525685 Tue May 09 2017 9:56am
CANROVER
Bah!!! You think???? Dude it's a Range Rover lol, this is just a band-aid. At the least, it will buy me time. Whistle
In the meantime I am now getting some weird smell coming form the rear left area.... Yesterday morning while it was limping on the bump stops I was on the highway jumping around at around 100KPH so I'm wondering if I may have blown a seal somewhere. If I remember correctly, the air bag provides the cushioning while the internal pneumatic shock does the rest.... Just a guess.
Is it possible the smell (smells a little like burnt brake pads) is coming from the pneumatic half of the strut? I checked the rear discs and they are fine.
Post #525694 Tue May 09 2017 11:44am
Socast
The air suspension on the RRS works the same as a MacPherson Strut, theres a hydraulic damper in the centre with the air bag replacing the coil spring. So I wouldn't have thought the smell would be coming from the suspension. I'm not sure what size wheel/tyres you're running but when on the bump stops they could've been fouling on the body somewhere. The other possibility is that the geometry is all wrong when dropped that low, so you will have been scrubbing your tyres so it could be that.
Post #525704 Tue May 09 2017 12:41pm
CANROVER
You know what? I have to say these trucks are pretty poorly designed underneath. a few days ago I had a look underneath and the amount of exposed wires is incredible..... All that's required is a simple plastic cover or cowling to cover it all up and theses parts would last so much longer. It really is astounding how such a prestigious and high priced vehicle lacks this simple forethought.
I don't know what the Brits and the Europeans used for traction on the roads during the winter but here in Canada we salt the crap out of the roads and you should see how incredibly corrosive all that salt is. What's worse is that it gets into every nook and cranny making sure to kill whatever isn't protected. Very sad Big Cry
Post #525710 Tue May 09 2017 1:37pm
CANROVER
I thought that too Socast but the tires showed no sign of gouging or damage due to contact with the well. I'm running stock rims on 274x45 R20 so that's not too bad. Admittedly, the tires were pretty close to the wheel well but this morning all was normal so that smell??? No clue where it could be coming from.
Post #525712 Tue May 09 2017 1:47pm
